Anyone got a few hints on what I should look for as there is nothing in the manual
70 series factory diff locks
After having my left cv and axle replaced - I no longer have working front diff lock
1988 - cable diff locks - - i will put on the stands again when changing back to the Simex's and re-check that I am not dreaming.
hmmmmmm - axle - I will check with the guy who fixed it - the axle was a stronger version that came from Australia - it had to be changed here because they left off a circlip ring gap
Thats a good question.
Did you have the diff lock engaged when you removed the front axle. Sometime the dog clutch can be knocked free of the fork if the axle is removed.
Is it a coil 70 or a leaf sprung.
Also is the axle you pulled out the long spline axle or the short pline. If you replaced long spline with a short spline you will have issues.
G
G
Jungle wrote:Thats a good question.
G
Leaf spring and the axle should have been the same - will check.
If the axle is the same - then remove diff head
I would take the front diff out and see if the dog clutch is ok.
What I meant to say before was the I always lock the diff heads up when removing the axle. that way the dog clutch is locked together and makes inserting the axle back in easier. Plus you need the diff lock engaged when removing the diff head so you can get the diff head out.
You'll see why when you have it on the floor.
Good fun.
G
Good fun.
G
Re: 70 series factory diff locks
BrentC wrote:After having my left cv and axle replaced - I no longer have working front diff lock
Finally have had the diff head popped - the previous dip stick mechanic put in an axle short on splins
or can recommend where to get one - IcedJohnno
- Trailer Trash
if you cant find one brian howat at howat engineering could make one for you ,only problem is that hes pretty busy and not sure how soon he could do one .i think he charges under $200 bucks for an axel out of 4340
- skid
- Tyre Man
sig wrote:if you cant find one brian howat at howat engineering could make one for you ,only problem is that hes pretty busy and not sure how soon he could do one .i think he charges under $200 bucks for an axel out of 4340
does he do 80 series for that price sig
Thanks - I have another one coming from Australia - which will mean I will have a one that have burred splines, one where the splines aren't long enough to engage the diff locks and hopefully a correct good one
hey man i know your pain!!
i went on the auckland members trip started of by blowing left cv mudlva had a spare so being the top guy he is helped me pop it in. then oh no theres a funy sound in the front end. so called it a day and drove it to a good mate of mine. he's a mechanic
so long story short i'm now lookn for left axle both cvs ring and pinion and pinion bearings
yay for lockers and the inexperienced driver !!! haha turned into and expensive day
