kaney wrote:and where to find the oil pressure sender on the 2l-te
It is on the right hand side of the motor at the back nere the bottom.
It is a round cylinder with one wire going to it and it also has a joining plug up by the alternator wireing
if you get stuck bill come round and have a look at mine, it's a 2L (non turbo) on the supra engine, swaps straight on don't know if it reads right tho
I had a good look through the Tridon catalogue yesterday, almost all Toyota Diesels and some Toyota petrols use the same water temp sender and the same oil pressure switch/sender. So I've they are getting me a couple of oil pressure senders to check the thread. Then I can swap the switch out with a sender. From memory the following motors have the same senders..
2JZ-GE & GTE
7M & 5M
2LT, 22RE, 1KZ
They were just some of the ones I could remember....
The warning light on the oil sitch for all of them comes on at 0,2 Bar which is supprising ...
Who knew Prados could fly?
