Cloggy_NZ wrote:Where are you going to find another Diehatshoe to make up your team Jerry?
The tip?
Jerry wrote:The purpose of this day is to give some informal guidence and training on performing safe recoveries and also a session for those running & organising trips on safe working practices before/during and after a trip and if incidents occur. Bring your extra recovery gear we can have some team challenges and try out different methods of recovery.
We can discuss the recent towhook incident as well (with the purpose of preventing this happening in the future) I can arrange someone to look at your hooks and see if they are safe enough as well.
warlord225 wrote:you didn't block the humps did you, if so I suggest that who ever did gets down there and unblocks them.
don't take that in an angry tone, just a normal suggestive tone
Jerry wrote:Date : Sunday the 29th of April
Drivers Briefing / Start Time: 10.00am
BBQ Lunch $2 per person
Bookings are required
Rated Towhooks are required (mounted properly) if you are using the hazards.
There will be time for a general play afterwards, there may be some pegged hazards to try out as well....
ANYONE IS WELCOME THIS IS OPEN TO EVERYONE ON ORE
HighCountry wrote:Hi Guys. Just got a couple of things to throw into here for a bit of thought........(NOT as for a means of my being 'shot down in flames'....)
1) 'Rated towhooks are required' - usually accompanied by the words 'front & rear....' - define 'rated' - would this be the 10,000lb rated hooks that can be brought?? That we then hook a 8,000kg snatch strap onto...?? (I'll let you do the conversion maths...!!) How do we fit one of these onto a late-model vehicle?? How do we maybe fit this to a vehicle with air-bag triggers in the front of the chassis.......?? Have seen suggestions here on the forum, about drilling the chassis / fitting crush-tubes / H-T bolts etc - whilst a great idea (I'm not knocking it..) - is LVVC then required for 'chassis mods'..........?? Is just a thought.........
Rated hooks to the rear, ALWAYS gets me going.........does this mean a shackle through the towball hole on the towbar, is not considered good enough.........?? Or is this 'less safe', or maybe 'more safe' than a 'rated hook'...??? How bout using a receiver type hitch, will the pin through the strap-eye...........??
2). Have seen forum suggestions that a 'dampner' be used on snatch-straps, as added protection for if something breaks. THIS IS A FALLACY!!! Go out - experiment a bit - break a 'hook' with no dampner on the strap - then break another 'hook' with a strap thats got a dampner over it - come back - tell me what the differance is. Then if you really want to see how (in)effective a dampner is on a snatchstrap, have the hook 'break', while its got a 4.7 rated shackle on it.............![]()
3). As well as all the the 'hornets nest' thats contained within the tow points / rated hooks / etc, etc (and theres a couple....), the other factor that comes into it, is theres lots of people that don't know how to properly use a snatch-strap!! And, they just have absolutely no idea of the forces involved when using one........!! Which is all ok - till something goes wrong / something breaks.
4). Been talk of a 'safety-strap' attached to the eye of a snatch strap - good idea, providing the tree-trunk protector being used has a higher 'break' rating than the snatch-strap, & is secured around something that will never break.
5) Snatch-strap ratings - CHECK WHAT IS BEING HOOKED TO YOUR VEHICLE, FOR RATING, AND CONDITION!!!!! Not really shouting - just trying to make sure people take notice. Beware, that there are snatch-straps out there, that are only rated to 4500kg. Personally, I will NOT be using anything with that low a rating, when its hooked to my 3000 kg Landcruiser (not that Toyota's get stuck or anything........![]()
Why have I said this?? To offer a few things that maybe should be discussed at your upcoming training guys. For recreational 4WDing - I believe we all have 2 main objectives when we go out - have a bit of fun - & be able to go home safe at the end of the day. Even if 'only' snatching out a stuck truck - don't compromise your being able to do the 2nd objective.........
Cheers - P.
HighCountry wrote:Jerry wrote:Date : Sunday the 29th of April
Cheers - P.
You and jerry sound like a match made in heaven
Do a towhooks search on the forum, this hads been discussed time after time.
do we really have to bang on about this?, go do a serch buddy, and/or turn up this sunday
