I have an old 4l turbo diesel cruiser and I installed a bleed valve on wastegate signal line to adjust boost.
This part works great- from in the cab you can adjust boost from std 8lb to 14lb watching pressure gauge. -cost about $30 from surplustronics and HCD.
Problem is it didnt do anything
because the factory boost compensator doesnt seem to move further than about 8psi...
somewhere there is a full load screw you can wind out but i dont know which one it is.
I wound out the 'full throttle stop screw' and all it did was make the auto shift later
so i wound it back. anyone have a picture of which screw to muck with? I also dont want to harm engine, anyone have any experience with these engines? Ive heard they are a Hino truck motor and will kill you before you kill it
