arbhilux wrote:just wondering did you use the back disks that came out on factory 70 series or the front ones on doing your disk brake rear end set up thanks
rears
Steve_t647 wrote:They are a drum handbrake and a disk foot brake system
fweddy wrote:Steve_t647 wrote:They are a drum handbrake and a disk foot brake system
So when those disks are being used I take it the drum is just ignored and hence why the MR2/subby/maxima etc callipers are used rather than prado?
What combination did you use Tim?
IcedJohnno wrote:I normally don't bother with the handbrake (a product of growing up in freezing winter climates and working on the Ice) however with a turbo timer this is a pain I A.
hosehustler wrote:All of whats been said is 100% correct, the drum type handbrakes (inside discs) goo up, wear out fast, etc, however they have far better holding power when applied.IcedJohnno wrote:I normally don't bother with the handbrake (a product of growing up in freezing winter climates and working on the Ice) however with a turbo timer this is a pain I A.
Oooooh I have a turbo timer.....and and AUTO with that magic little "P"
fweddy wrote:What sort of hand brake mech do those prados use? I guess its not a viable option else it would be being used?
Has any one tried using a drum hand brake setup like most cars do with rear disks. Just pulled the wheel off a 90 series and had a look under there - without pulling the calliper off and removing the disk its hard to see how it could be mounted but is that an option? It appears the mounting bolts have a different pattern but are there more issues than that?
In the pic below you can see the manually operated cable for handbrake, this is a mechanical set up in the MR2 calliper I used, similar to the Subaru, and Mitsi which have also commonly been used.
This set up won't ever give the same handbrake power as the drums, however it is good enough if set up properly for cert/wof, and is as reliable as hell for offroad....perfect for a conversion.......no more drums![]()
Oh and I had 2 new cables made for the task, they utilise the exsisting hilux lever inside the cab.IcedJohnno wrote:I normally don't bother with the handbrake (a product of growing up in freezing winter climates and working on the Ice) however with a turbo timer this is a pain I A.
hosehustler wrote:Cheers for that Richard, I may go that way if I ever have WOF issues, having said that I have to say that the current set up is way better than adequate, superior to the old Mitsi callipers I had on the earlier sur, passed Certification and WOF
haynzy wrote:hosehustler wrote:Cheers for that Richard, I may go that way if I ever have WOF issues, having said that I have to say that the current set up is way better than adequate, superior to the old Mitsi callipers I had on the earlier sur, passed Certification and WOF
Hey m8 any pics or diagrams of how you ran the cable, no point reinventing the wheel
Jezza wrote:Looks bloody good, are you going to have another shot at that hill?
PigFmr wrote:looking good there tim ,and no i aint done much more to mine as yet,bloody harvest is neally ovr now and then back into it,u going to lake daniels?? maiden trip ??
vince
Jafa wrote:Good stuff Tim, looks the shizzle. We'll have to catch up for a wheel at RR10, if it ever happens, probably more chance of catching up on the West Coast somewhere
