SMOKEY wrote:Hi Skid, if you are suspicious of the tank/fuel filter, get a 4lt; container a length of fuel hose and connect it straight to the lift pump, the return will still use the original system. I am not that familiar with the 80 series injector pump or fuel system but it is not that uncommon to have fine gauze filters fitted inside fuel line banjo bolts and where the fuel line enters the injector pump. If I get time tomorrow I will give my Diesel Pump service man a call. There won't be to much wrong with it,
IT'S A TOYOTA,
FITZY.
cheers fitzy
forgive my lack of mech skills, but is the lift pump you refer to, the internal pump in the tank
it actually ran sweet as, for my flatmate today after I had blasted the fuel line back to the tank.
So once the weather calms down and the rain isn't coming thru the carport sideways, we are gonna pull out the shit in the back and roll back carpet and go in from the top to see if theres shit in the tank or anything.
at the moment its still being used as the flatties shitty holden( some folks never learn) is still puckered.
seeing as how I have a company car, once the 80 is not needed it will be dealt to to determine the problem among other things
thanks again
SKID
