Page 2 of 2
Re: Any sugestions for clubmans rules??
Posted: Thu Jan 31, 2008 8:42 pm
by TJ
Shane wrote:Can Low mount winches run synthetic rope with out melting it or making it go like plastic?I have heard you can buy it with a protective cover on the first 8-10meters? have not seen them myself.
Internal brake and synthetic rope is only an issue when you are using the winch to roll yourself down a hill (in reverse) i.e. you are using the brake to slow your descend while lowering yourself or holding yourself. Winching in normal (forward) direction will not heat up the drum (with the brake inside), so running a synthetic rope is not a problem. Besides not all low mounts winches have internal brakes (eg. Superwinch EPI 9.0 does not).
Posted: Fri Feb 01, 2008 3:22 pm
by darinz
Most of the new model of winch are fine with synthetic. ie All the Come-Up, Superwinch EP9 (a Come-Up copy), most of the 9500lb winchs (reputable brands) are good as well. The brakes in these winch are different to the old type that generated heat.
Posted: Fri Feb 01, 2008 4:42 pm
by Shane
The factory nissan winch,Warn M8000 have the brake(one way clutch)in the middle of the drum correct?
This holds the vehicle when say winching up a hill and you stop for some reason,it holds the vehicle(stops winch from unspooling)correct?
Cheers Shane
Add synthetic rope to the every growing list :D
Posted: Fri Feb 01, 2008 8:57 pm
by darinz
Yeah it is in the drum and therefore the M8000 is no good for sythentic long term. I've heard people using it without issues but the heat i going to effect the life of the rope.
Posted: Sat Feb 02, 2008 5:40 am
by 4wdRick
Off to the meting now, will post results.
Thanks for all the input, it's just what is needed.
Rick
Posted: Sun Feb 03, 2008 7:41 pm
by PigFmr
had a good meeting got loads sorted its going to a good series around the south island this year
will let Rick fill you in on the rest of the details for rules for clubmans and open class and what the winch series is going to be called for the south island, as Rick started this post off,good on yer Rick for your support
Vince
Posted: Tue Feb 05, 2008 5:48 pm
by diffsx2
hey rick ya gonna let us know what the guts was with the meeting and the outcome of the rules situation? cheers dude...
Posted: Wed Feb 06, 2008 8:09 am
by 4wdRick
Waiting for the official rules to be released before I put them on the web, don't want to jump the gun. :D
Will be listed before Friday arvo.
Posted: Thu Feb 07, 2008 4:00 pm
by jeremy
I know it's bit late now but saw this posted on Outerlimits regarding the new CCDA (aussie) rules for their trophy class (which I suppose is an equivalent of what I presume is trying to be achieved with a clubmans class).
Specs for NEW Production Class include:
No Turbo or Super Charged Petrol
No Intercooled Diesel
Engine must be of same make & model as vehicle (eg no 4.5 or 4.8 in GQ)\
Can run aftermarket engine mgt system
No 24v winch
Single Shocks
Body must retain origional shape (no ute conversions)
Origional wheelbase to be retained
35.5" x 13.5" max tyre size (must fit through gauge 901mm x 343mm)
No replacement guards or bonnet
Must run synthetic rope
Can run laminated diff & upgraded CV & Axels
Full topic can be read here... http://www.outerlimits4x4.com/phpBB2/vi ... sc&start=0
It was also mentioned that a 4 point cage would required for the Vic Winch event (their entry level comp) and a 6 point cage required for the Outback challenge, Cliffhanger, Alpine challenge and all the rounds of the Engel series.
Their rules seem like a good balance, allowing for someone with a fairly standard truck with 35's (which is pretty much the standard these days) to have a go, but not sacrificing any of the safety requirements (roll cage, harnesses, helmets, synthetic rope).
Anyway, that was just an FYI post. I'm looking forward to see what you guys down south came up with when your rules are released. Good on you guys for getting together to grow the sport - the future just keeps looking brighter for Winch Challenge in NZ.
Posted: Thu Feb 07, 2008 4:05 pm
by jeremy
In other more exciting news... Hot of the press, a major 4 day winch challenge event is planned for october 08.
Initial press release can be read here... http://www.4x4challenges.org.nz/news/48
As I understand it the organisers are pretty keen to get some teams up from the south but I'm sure they'll chime in later on and let us know all the finer details. It'd be great to see you guys racing up here in an epic north vs. south battle.
I'll be posting any info on the 4x4 challenges web site as it comes through to me, so stay tuned.
Posted: Sat Feb 09, 2008 5:41 pm
by toysuzi
any have the new rules to post up yet
Posted: Sat Feb 09, 2008 6:50 pm
by swampa
the first one is only 4 or so weeks away in southland, so if things need to be changed, roll cages certed, that sort of thing, that might be pushing it a bit close
Posted: Sat Feb 09, 2008 7:04 pm
by 4wdRick
Mainland Winch Challenge Rules
