Transfer case blunder!
Posted: Sat Mar 29, 2008 8:02 pm
Hello there, I recently embarked on the journey of converting my vacuum engaging 4wd system on my 1980 FJ40 Cruiser to a manual engaging system - the old system as playing up toooo much! Anyway I successfully did it which was great! quite an easy task in the end....
Anyway, my blunder is this.... the high low shifting shaft that comes out the top of the transfer case (later type transfer case) has slipped into the transfer case
when I had the shifting lever off it was fine, it wasn't until I went to refit the new system that I stuffed up and it slipped about 4-6mm below the surface of the transfer case....
Anyway, I tried a few things (I didn't want to pull the box apart just to slide a wee shaft back up!) I tried gluing a wee screw onto the shaft - no go... it was a 'hope' I also tried removing the PTO cover from the other side of the box and you can physically see the shaft sitting there but there is nothing I could use that would push it back as I couldn't get under it and if I did had no leverage to slide it up... things are very slippery in there! I then thought I might be able to take the plate off that the rear drive shaft comes through as the shaft is right there... but no luck... no access! to the shaft.
So I have to concede defeat and look at the option of pulling box apart...
From what I can see I should be able to take the rear cover off the transfer case? (I have never pulled a gear box apart before, so some input to confirm my plan would be appreciated.... I am capable.... but not trained! could be a bad thing I reckon!) anyway, can someone tell me if unbolting the whole rear cover off the transfer case and pulling it off to get this shaft back up will the box fall apart and I'll end up with a thousand pieces or will I be lucky and pull the cover off with nothing falling out so I can carefully push this shaft back up and refit the back cover and get on with playing in the mud?
Thanks for any input!
I am at the stage where I probably should take it to a mechanic but funnily enough the transfer case is in neutral so I can't even shift the truck into the garage from our gravel driveway let alonoe drive it into a garage!!! we also live 20-30min out of Invercargill in the middle of no where...
Chris
Chris
