Anyway, my blunder is this.... the high low shifting shaft that comes out the top of the transfer case (later type transfer case) has slipped into the transfer case
Anyway, I tried a few things (I didn't want to pull the box apart just to slide a wee shaft back up!) I tried gluing a wee screw onto the shaft - no go... it was a 'hope' I also tried removing the PTO cover from the other side of the box and you can physically see the shaft sitting there but there is nothing I could use that would push it back as I couldn't get under it and if I did had no leverage to slide it up... things are very slippery in there! I then thought I might be able to take the plate off that the rear drive shaft comes through as the shaft is right there... but no luck... no access! to the shaft.
So I have to concede defeat and look at the option of pulling box apart...
Thanks for any input!
I am at the stage where I probably should take it to a mechanic but funnily enough the transfer case is in neutral so I can't even shift the truck into the garage from our gravel driveway let alonoe drive it into a garage!!! we also live 20-30min out of Invercargill in the middle of no where...
Chris
