May be the 2LT (not the 2LTE?)
BUT IT HAS A FACTORY DIFFLOCK
http://www.trademe.co.nz/Browse/Listing ... =148726795
CHEAP SWB LJ7x Prado on TM
Re: CHEAP SWB LJ7x Prado on TM
its already on my watch list .i was hoping to keep it quiet hopeing for a bargain (next project)
but jerry has let the cat out of the bag .ooh well it might still go cheapish
if you get it cheap I am keen on parts if avaliable
if i do get it all the running gear will be for sale
bugger off the pair of you I need to buy it for the diffs, I neeed that ratio (and lockers) I am Jagmanxj6 on there, also I will be stripping all for parts so will let the un needed stuff go cheap on here......
If you follow me in the bush you must be mad cause I'm plain CRAZY !!!
1987 BJ74, 13BT, Auto, 35" Wranglers, 80mm Suspension Lift, 2" body lift, LSD rear, ARB Front Locker, PTO, Lots of Steel and a Go Hard Driver.
