3L Head on 2lte Block
eejay99
Post by eejay99 »
Hi Guys,
Got the head off the Surf, showing some corrosion damage and cracks through the valve stems surprise surprise...
I am looking at putting a 3L head onto the 2lte block, does anyone know of any pitfalls or things I will need to watch out for, or take into account in my budget?
I.e Are timing belts, drive belts, gaskets interchangeable between the 2lte and 3L? Or do I need a new setup
The replacement head I am looking at getting is fitted with camshaft, valves and precups. The 'Auto Parts Distributors' one from Auckland off Trademe.
Cheers team, you guys are always helpful!
tweake
Re: 3L Head on 2lte Block
Post by tweake »
http://www.toyotasurf.asn.au/forum/ has all the answers.
he will bolt straight on, need to change the exhaust studs around a bit.
only thing was which headgasket. i think some mod the head gaskets to help with cooling of the head.
eejay99
Post by eejay99 »
thanks, help appreciated
