Diff question
Posted: Wed May 14, 2008 7:05 pm
by 86-surf
HOW the fock do i get the drum off?, i took the wheel off and tryed to pull it off just like you would with a datsun or holden drum?, But the focking thing wouldnt budge.. How do i get it off?.
I need to replace the shoes but can't get to the shoes to take one in to repco.
Repco has two types....
HELP PLEASE.
thanks
Re: Diff question
Posted: Wed May 14, 2008 7:07 pm
by wopass
jacking bolts
Re: Diff question
by skid
just because its you jase
HAVE YOU TAKEN THE HANDBRAKE OFF
Re: Diff question
Posted: Wed May 14, 2008 7:15 pm
by Engineer
skid wrote:just because its you jase
haha yea!
jacking bolts or whack it with a hammer until it comes off!! works everytime for me
Re: Diff question
Posted: Wed May 14, 2008 7:18 pm
by 86-surf
yea hand brake was off. i geuss i will just wack it with a hammer if that don't work ill get a bigger hammer. .
thanks.
Re: Diff question
Posted: Wed May 14, 2008 7:22 pm
by wopass
Engineer wrote:skid wrote:just because its you jase
haha yea!
hahhha yea hand brake on...lmao
only peeople skilled in the art of breaking a drum loose with a hammer blow should use that method, last person i saw try that ended up having to replace 2 studs
was funny at the time. jacking bolts for beginers
Re: Diff question
Posted: Wed May 14, 2008 7:32 pm
by skid
Re: Diff question
Posted: Wed May 14, 2008 8:05 pm
by Sadam_Husain
Turn the adjusters to release the pressure between the shoes and the drum
If the adjusters go tight your turning them the wrong way
Re: Diff question
Posted: Wed May 14, 2008 8:08 pm
by tgaguy1
Jase, try backing off the adjuster screw first. Sometimes if the linings in the drum are worn, the shoes sit in a grove and prevent the drum from being removed. Be very careful with the jacking bolts. Hilux drums have only a couple of mm material thickness which the thread is tapped into. The thread is a M8x 1.25 so that means there is only two or at the most 3 threads to apply pressure from the jack bolts. The threads strip very easily (this I know from experience).
Good luck
Jase.
Re: Diff question
Posted: Thu May 15, 2008 10:35 pm
by scs
I had one that was so ####### stuck, completely unadjusted, spigot cleaned up, it still stripped both jacking threads, wouldnt budge with a hammer. ended up welding a couple of bigger bolts onto it and using a puller pushing on the center spigopt to get it off. sometimes they're just an asshole.
Re: Diff question
Posted: Thu May 15, 2008 11:37 pm
by taz01
or do what i do which is when ya brakes no longer work .....get another truck it was cheaper?????????
Re: Diff question
Posted: Fri May 16, 2008 10:05 am
by 86-surf
lol well it's alldone now.
I used two jacking bolt's and instead of threading them in, i got some plyers and a thin peice of wood and used the plyers as a lever on one of the studs. it worked a treat haha.
it was allsweet after that..
Re: Diff question
Posted: Fri May 16, 2008 8:07 pm
by monaro427
stick disc's on like i have and have no more problems
Re: Diff question
Posted: Fri May 16, 2008 8:26 pm
by 86-surf
i will oneday....
if some one could make me up the mounts for the callipers ill be strait into it!:D
Re: Diff question
Posted: Sat May 17, 2008 12:58 pm
by nstg8a
taz01 wrote:or do what i do which is when ya brakes no longer work .....get another truck it was cheaper?????????
thats sorta what i did with my old surf, my hand brake was always pretty average, did a lsd swap, but a total drum to drum swap, not just diff head, and hey presto, fixed my handbreak problem...
