Cutting out
eejay99
Cutting out
Post by eejay99 »
Hi There,
Just replaced the head on my 2lte with a new 3l head, motor fired up first time and ran smoothly,
However, when decelerating or sitting at idle the motor cuts out,
When putting the new head on I took the time to block the egr valve with a blanking plate to the intake manifold end. Checked timing and all, looked good. Idling a bit low at 600rpm though
I am picking that the low idle is the problem, that or fuel or air supply. how can you adjust the idle?
Any help would be appreciated, thanks in advance
tweake
Re: Cutting out
Post by tweake »
sounds like incorrectly adjusted tps.
also disable egr buttefly in the intake.
