80 series flywheel bolts
Jungle
Post by Jungle »
Half way through an auto to manual conversion and we need 8 flywheel bolts. I knew something was missing.
Its an 8 bolt flywheel. Flywheel bolts off a 1HZ or 1HDT should do the job.
Does anyone know who sells them or has a dead engine lying around.
jungle
wopass
Re: 80 series flywheel bolts
Post by wopass »
probably find they are the same right thru the range mate, so i would almost put money on a 2F having the right bolts you need. had you asked before i moved i would have had some... but a lot of stuff got dumped :cry: have you tried ripco for flywheel bolts new ? might be surprised.... i know thay have all sorts of bolt kits available now :wink:
Jungle
Post by Jungle »
I tried most wreckers in NZ for some flywheel bolts. The flywheel had no dowels so I assumed the flywheel bolts would be a very tight fit. Have sourced some out of Aussie and hopefully they will arrive tomorrow.
Jungle
