safari spring sag
Posted: Tue Jul 29, 2008 8:59 pm
by mudhunt
I am running 3" lift dobinson springs in my gq swb. I noticed after a few drives it leaned over quite bad to passengers side. I replaced the back passenger spring and i thought that fixed it but its really obvious again. I dont have a spare mounted on the back atm which i know could do a little but its very pronounced looks like an inch or more out of level. Anything else that can cause it. WHo uses " springs and what brand.?
Re: safari spring sag
Posted: Thu Jul 31, 2008 7:01 pm
by Dak
All I've ever used are OME ones, current set has been used and abused for around 3 years now and my truck is still within 5mm of what it was when they were first put in.
Posted: Fri Aug 01, 2008 6:37 am
by albundy
Get some spring spacers to even them up, or try swapping them from left to right. Common problem, I had it with my OME, and now that I have changed to TJM not there anymore.
Al
Posted: Fri Aug 01, 2008 5:40 pm
by DaveM
Is it the same side the old coils sagged on? If it is, I'd give everything a check to see if its something else causing it
Posted: Fri Nov 07, 2008 7:27 pm
by Mud Hog
I have the same size lift in the same brand I find them very good havent saged a mm in three months, sounds like theres some thing else going on, have had a good look at there seating? others suspension links? sounds weird there saging that much check spring measurements?
Posted: Sat Nov 08, 2008 6:01 pm
by Mud Hog
also make sure you have the left springs on the left side ect.
