safari spring sag
For all Nissan related topics
mudhunt
safari spring sag
Post by mudhunt »
I am running 3" lift dobinson springs in my gq swb. I noticed after a few drives it leaned over quite bad to passengers side. I replaced the back passenger spring and i thought that fixed it but its really obvious again. I dont have a spare mounted on the back atm which i know could do a little but its very pronounced looks like an inch or more out of level. Anything else that can cause it. WHo uses " springs and what brand.?
Dak
Re: safari spring sag
Post by Dak »
All I've ever used are OME ones, current set has been used and abused for around 3 years now and my truck is still within 5mm of what it was when they were first put in.
albundy
Rolly Polly
Post by albundy »
Get some spring spacers to even them up, or try swapping them from left to right. Common problem, I had it with my OME, and now that I have changed to TJM not there anymore.
Al
DaveM
Post by DaveM »
Is it the same side the old coils sagged on? If it is, I'd give everything a check to see if its something else causing it
Mud Hog
Post by Mud Hog »
I have the same size lift in the same brand I find them very good havent saged a mm in three months, sounds like theres some thing else going on, have had a good look at there seating? others suspension links? sounds weird there saging that much check spring measurements?
GU patrol 35s ect.
Mud Hog
Post by Mud Hog »
also make sure you have the left springs on the left side ect.
GU patrol 35s ect.
