1. When cold it does not wont to engage overdrive untill it has traveled a few K's ( 6-10 ? ) and presumably warmed up.
2. What does the HOLD-POWER-AUTO switch do. I assume Power and auto are fairly self explanatory and I have found that HOLD seems to lock it into 2nd gear when in low range. I have put in low range reduction gears which has made a huge difference to its offroad ability and it would be nice to also be able to lock it in 3rd as on steep climbs it will kick down to 2nd causing a loss of momentin when in fact the truck has plenty of power to hold 3rd.
3. Is my Overdrive lockup clutch disengaging to easily ?. When engaging Overdrive the torque converter steps up allright and drops engine revs and then a second or 2 later the lockup clutch engages dropping the engine revs another 1-200 rpm. This seems all normal and good so far and it will stay locked in when cruising or under load but as soon as the load comes of like slowing down for a corner or going down a hill the lockup clutch disegages and then when the load comes back on the lockup clutch has to reingage again. In some situations this can be happening quiet frequently. Is this normal and does it wear the lockup clutch.
4. Oil level. My dipstick mark has COLD on it. I assume I take the reading with the oil cold, motor running and auto in neutral.
I have a bad electrical connection in my instrument cluster as sometimes my speedo and odometer does not allways work straight away when cold but this does not seem to affect the auto in any way even regarding question 1 .
Some where along the way I read something about the solenoids in the auto can fail causing damage to the auto ? Is this correct and what symptoms does it exhibit.
Any other info on fine tuning these auto's for offroading would be much appreciated
