Just wondering what people are running in the way of egt gauges?? and where ya got them from,,,,cost etc ?? need to fit one cheers
Bushrash
Bushrash wrote:hey all
Just wondering what people are running in the way of egt gauges?? and where ya got them from,,,,cost etc ?? need to fit one cheers![]()
Bushrash
Bushrash wrote:Hey
yeah thinking it will be a handy tool,,just looking at different brands ,,, and setting it up and having a play on my na engine to get the drift of things and plumbed ,,, then put in on my turbo engine you guys running them pre turbo i presume??
Windsock wrote:Bushrash wrote:Hey
Nuh, running it on a normally aspirated diesel, no turbo. Been reading around and some folk reckon you need them on NA diesels more than on turbo'ed ones. Dunno what to think of that but just like knowing what the loud pedal does to the EGT's
Bulletproof wrote:Windsock wrote:Bushrash wrote:Hey
My hilux runs a supercharger and intercooler that is manually controlled. With out the supercharger turned on it is very scarey as the pyrometer very quickly will rise from 400 to 700 within seconds rather than minutes going up a hill. The boost from the charger reduces it instantly 150 C .So a NA motor definately needs one more than a boosted motor.
Cheers Richard
cool__bananas wrote:
but richard, wont your motor work harder with the supercharger turned off because its trying to suck the air through the screws which are stationary (or near it) rather than a NA motor which is just sucking through a pipe?
Bushrash wrote:they come with senders?? if they do the egt a screw in sender??
KiwiBacon wrote: NA diesels don't need them because the smoke out the back tells you everything you need to know. It's diesels that are forced induction (turbo and supercharged) which can reach the truely dangerous levels without much smoke.
Windsock wrote:yep, that'd be right, but with a wing mirror constantly getting banged off the veiw of the tail pipe and it being somewhat odd behavior to be looking backwards while going forwards, I have found the EGT gauge beside the steering wheel to be a simple solution that satisfies a morbid curiosity about what of my behavior causes the engine to get hot and what cools it again...
KiwiBacon wrote: What sort of readings are you getting?
I have a NA work car which I will eventually turbo, I hope to fit the EGT gauge sometime before the turbo goes in.
KiwiBacon wrote:I'm also running VDO. The different ranges are AFAIK just different styles. Mine is black with green backlight to match my factory dials.![]()
If it's smokin, it'll soon be broken.
Bushrash wrote:what did ya vdo gauge set ya back kiwi??sounds like the sort of set up i need cheers
Windsock wrote:KiwiBacon wrote: What sort of readings are you getting?
1984 Land rover 110 powered by 1986 LD28 in good condition 170000km - redline 5000rpm (now got car tacho transplanted into LR)
4500rpm getting outa mud - 550-650C
2000rpm climbing Takapari road - 250-300C in appropriate gear
2000rpm climbing Takapari road - 500C+ in too higher gear
3000rpm along the flat road and calm wind - 400C
3000rpm along flat road and into headwind - 550C
2000rpm cruising along tracks low 4WD - 250C
idle and cold <100C
Down the driveway, onto road and into 3rd gear before gauge shows 100C![]()
idle and hot 150 -200C
All in all I think all reading are expected and well within acceptable levels. Real eyeopner though... headwind one was interesting - LR has aerodynamics of a flying brick sideways
Driving behavior is now modofied somewhat with respect to gear selection on climbs... I use moreys additive and so smoke is somewhat minimal when it is there.
KiwiBacon wrote:Bushrash wrote:what did ya vdo gauge set ya back kiwi??sounds like the sort of set up i need cheers
It was heaps, somewhere over $400 I think and that was with a good discount.
You can get EGT gauges cheaper online but it can be hard to find metric ones.
KiwiBacon wrote: You're far from burning anything with those temps.
Your engine is at it's peak efficiency just before it starts to smoke, changing down a gear uses a whole lot more.
Bushrash wrote:It was heaps, somewhere over $400 I think and that was with a good discount.
cool__bananas wrote:i might have completly missed this but what exactly does a egt gauge do? just tell you the exhaust temp which lets you know how hard the motor is working?
91Rangie wrote:From another post http://www.jaycar.co.nz/productView.asp ... &SUBCATID=
Windsock wrote:KiwiBacon wrote: You're far from burning anything with those temps.
Yep, sure thing. Given that I have read of many different "hot" temperatures, 720-770C appears to be the level some folk say damage occurs at. So, yeah, no where near at normal driving. Only really pushed it the once getting outta the mud that - 650C briefly. All the temps listed have been with an empty flat deck and steady driving. Purposely haven't gone anywhere with a big load on the truck since installing gauge to assess what empty truck EGTs were. Now I have figured a sort of status quo EGT level, I can now load it up and see if loads make any serious inroads towards higher temps.
Found out today also, drafting behind a big freight truck lowered the EGTs by 70C...
Bulletproof wrote:Damage can occur before your 770C as steel glows red hot around 700 C and turbo fins can burn around 750C and also pistons can distort at those temperatures . Most ships maintain temperatures in the 400s.
With My hilux I work between 450-550 degrees C and have done so for the last 40,000 k with no noticable damage.
Cheers Richard
