new member, is this alright for a beginner?
Posted: Tue Nov 18, 2008 9:17 pm
by dave.oh
hey, my names dave and i live in pukekohe (auck)
i was actually after a cheap van but i saw this on trademe
http://www.trademe.co.nz/Trade-Me-Motors/Cars/Toyota/photos/a-188203716/p-80735109.htm
and thought it was pretty cool. the guy said reserve is $1500, so its pretty cheap. i dont really want to spend more than 2k
can anyone tell me what i have to look out for when i go and inspect it.
would the 2 litre engine be alright for offroading? and is a surf good for a beginner?
cheers,
dave
Re: new member, is this alright for a beginner?
Posted: Tue Nov 18, 2008 9:33 pm
by coxsy
well if it can get up thompsons track,an hill and that angle should be a good buy :D
Posted: Tue Nov 18, 2008 9:42 pm
by dave.oh
also ill need it for a daily driver, are these models reliable? ive been told that the mud tyres will wear out quite quickly on the road, so was thinking of getting a 2nd set of wheels with road tyres on them. what are your thoughts?
i have also just seen this
http://www.trademe.co.nz/Trade-Me-Motors/Cars/Toyota/photos/a-188538610/p-80870132.htm
is there much difference between a hilux and a surf, other than body?
the lpg would be a bonus since its cheap to run, but does it still perform offroad?
Posted: Wed Nov 19, 2008 12:06 am
by kaney
that hilux would be the better of the two for someone that uses it as a daily in my opinion, also that way you can build it as you learn how to use it.
Posted: Wed Nov 19, 2008 2:54 pm
by PR
kaney wrote:that hilux would be the better of the two for someone that uses it as a daily in my opinion, also that way you can build it as you learn how to use it.
X2
Posted: Wed Nov 19, 2008 3:22 pm
by coxsy
is x2 the single or the double cab? :D
Posted: Wed Nov 19, 2008 3:40 pm
by PR
Double cab :wink:
Posted: Wed Nov 19, 2008 7:16 pm
by dave.oh
why is that? because of the tyres? do they have pretty much the same capabilities offroad?
can you get canopys for the double cab hiluxs?
Posted: Wed Nov 19, 2008 7:23 pm
by coxsy
yes you can get cano for them , why the others want you to get a truck with a leaky engine,not sure :shock:
Posted: Wed Nov 19, 2008 7:27 pm
by COMILUX
I would go for double cab also. has beam axel front suspention rather than inderpendant like the surf - work beter off road and and are easyer and cheaper to mod and work on.
Posted: Wed Nov 19, 2008 9:14 pm
by PR
COMILUX wrote:I would go for double cab also. has beam axel front suspention rather than inderpendant like the surf - work beter off road and and are easyer and cheaper to mod and work on.
Yea what he said :roll:
Posted: Wed Nov 19, 2008 9:17 pm
by dave.oh
is that water leak a common problem? easy to fix?
Posted: Wed Nov 19, 2008 9:23 pm
by PR
If it was a Landrover they come out of the factory standard with leaks :wink: but honestly you it would be an easy fix or just put a supra engine in there and then later on you can run big tyres :mrgreen: the toymoter boys will be able to give you better options and ways of doing any conversions :wink:
