new member, is this alright for a beginner?
dave.oh
Stropper
Post by dave.oh »
hey, my names dave and i live in pukekohe (auck)
i was actually after a cheap van but i saw this on trademe
http://www.trademe.co.nz/Trade-Me-Motors/Cars/Toyota/photos/a-188203716/p-80735109.htm
and thought it was pretty cool. the guy said reserve is $1500, so its pretty cheap. i dont really want to spend more than 2k
can anyone tell me what i have to look out for when i go and inspect it.
would the 2 litre engine be alright for offroading? and is a surf good for a beginner?
cheers,
dave
Re: new member, is this alright for a beginner?
well if it can get up thompsons track,an hill and that angle should be a good buy :D
dave.oh
Stropper
Post by dave.oh »
also ill need it for a daily driver, are these models reliable? ive been told that the mud tyres will wear out quite quickly on the road, so was thinking of getting a 2nd set of wheels with road tyres on them. what are your thoughts?
i have also just seen this
http://www.trademe.co.nz/Trade-Me-Motors/Cars/Toyota/photos/a-188538610/p-80870132.htm
is there much difference between a hilux and a surf, other than body?
the lpg would be a bonus since its cheap to run, but does it still perform offroad?
kaney
Post by kaney »
that hilux would be the better of the two for someone that uses it as a daily in my opinion, also that way you can build it as you learn how to use it.
toymota thats stock standard.
PR
In the crap again
Post by PR »
kaney wrote:that hilux would be the better of the two for someone that uses it as a daily in my opinion, also that way you can build it as you learn how to use it.
X2
(021) 02388443
is x2 the single or the double cab? :D
PR
In the crap again
Post by PR »
Double cab :wink:
(021) 02388443
dave.oh
Stropper
Post by dave.oh »
why is that? because of the tyres? do they have pretty much the same capabilities offroad?
can you get canopys for the double cab hiluxs?
yes you can get cano for them , why the others want you to get a truck with a leaky engine,not sure :shock:
COMILUX
Post by COMILUX »
I would go for double cab also. has beam axel front suspention rather than inderpendant like the surf - work beter off road and and are easyer and cheaper to mod and work on.
027 337 0579
PR
In the crap again
Post by PR »
COMILUX wrote:I would go for double cab also. has beam axel front suspention rather than inderpendant like the surf - work beter off road and and are easyer and cheaper to mod and work on.
Yea what he said :roll:
(021) 02388443
dave.oh
Stropper
Post by dave.oh »
is that water leak a common problem? easy to fix?
PR
In the crap again
Post by PR »
If it was a Landrover they come out of the factory standard with leaks :wink: but honestly you it would be an easy fix or just put a supra engine in there and then later on you can run big tyres :mrgreen: the toymoter boys will be able to give you better options and ways of doing any conversions :wink:
(021) 02388443
