Hi guys, i know i must sound a bit slow but how do i separate my axle from the cv on an 84 surf. in the process of putting my front hubs back together.
Cheers for your help.
Off to put new diff head in now
How do you separate axle from cv?
Re: How do you separate axle from cv?
theres a grove in the end of the axle with a little wire circlip holding it onto the cv, you should be able to knock the cv off with a bit of wood and a hammer
awesome thanks will give it a go
- hosehustler
another way is to get a piece of pipe that fits nicely over the axle and use it like a slide hammer (careful not to damage seal surface on axle), will then pop of the circlip mentioned
I hate signatures
bring it down here and ill whip it off for ya...
that sounds a bit queer ...
best you whip it off yourself
- BlackCruiser
gimmemud wrote:Hi guys, i know i must sound a bit slow but how do i separate my axle from the cv on an 84 surf. in the process of putting my front hubs back together.
Normally will pop off with a wack with a hammer but if stubborn lock axle in vice and give the CV a good wack with copper hammer or similar, if it does not move hit it harder and harder
Stupid hubs! I put it all back together and found i had missed a washer
. forgot to put the thrust washer on and looked at the bottom of the box when i had finished and thought hmm that looks important
. Too late to be bothered taking it back off again so will have to do it tomorrow.
And the cv is being very stubborn, will have to take it to someone's place who has a vice so i can get the bugger out.
Was hoping to use the truck tomorrow morning but stupid work got in the way of me doing the hubs during the week.
