Mistral any good???
Posted: Thu Feb 05, 2009 7:07 pm
by brianr70
Can anyone comment on a Nissan Mistral? [possible purchase] anything to watch for? :?: :?: :?:
Re: Mistral any good???
Posted: Thu Feb 05, 2009 7:14 pm
by Jerry
RUST ... check out the dedicated page on www.lvvta.org.nz
do a search on here as well, from memory the odd dodgy auto trans....
Posted: Thu Feb 05, 2009 8:17 pm
by abbo
Hi there i have one of theses for a work car. Jerry is wright watch out for the rust under the rear seats on the floor pan. Wof guys are checking them on sticker time.Had no problem with auto and had it in deep mud with work and havn't been stuck yet... :D So hope this helps had car for 3 years now and only thing that had to be done was the front brakes.....abbo :mrgreen:
Posted: Thu Feb 05, 2009 10:03 pm
by DieselBoy
I like them, good strong TD27t engine, solid coiled rear end, a good wheel base and width.
The main thing i like is that when you walk round the truck you see those massive front and rear bumpers........ :twisted:
I have yet to see it done, but imagine stripping them off, the approach and departure angles would be pretty sweet for not much wok, and a simple tube bumper could easily replace them. Would be much like a Suzuki Vitara with the bumpers removed.
Posted: Fri Feb 06, 2009 7:01 pm
by albundy
Wifes got one, real good on fuel, some shit blind spots with the A pillar though.
Posted: Tue Feb 17, 2009 7:20 pm
by long
Mistrals/Terrano/Terrano 11 i would put an aftermarket auto cooler on it as they tend to run real hot in the tranny when you start to work them real hard and as above rust under the rear seat on the floor seam watch out for the rust bubbles.
Posted: Sat Feb 28, 2009 9:30 pm
by Zukman
I've got a 94 model.Bought it with 75000 ks on the clock & has now done over 475000 ks with out any problems.I use it off road quite a bit.The rear axle articulation is very good.I agree about the bummpers & trans cooler.It can run hot in the sand & under load.
