Wanted - Hilux Front Driveshaft
SirGerald
Post by SirGerald »
Hi looking for a front drive shaft (with cardian joint) from a 4wd hilux pre 1985??
The driveshaft is shorter in length compared to the later model ones.
Fully compressed it is 500mm and about 630mm before it is coming apart.
Below is a picture of one that I'm looking for. Want to use it to provide drive to the rear diff on hilux running gear under a suzuki. Can cut down the one I have, but thought I would see if anyone had one floating around first.
Feel free to give me a text or ring on 027-4436665
Cheers STU
Team Lada Loves Sloppy Holes!!!!!!!!!!!!!!!
