rear diff for hilux
Posted: Thu Dec 08, 2005 7:02 pm
by 4wdnuts
got to pull the rear diff out of my 1990 hilux on saturday, its making a hell of a noise and grating sound when driving. does anyone know where to source one cheap? its an lsd one to. hopefully someone will have one lying around?
Posted: Thu Dec 08, 2005 7:11 pm
by hosehustler
i have an open (not LSD) 4.3 diff head which should be the same as yours, only taken out of a 1993 doublecab because we changed my fathers truck to 4.88 ratio's. cheap at $180
Posted: Thu Dec 08, 2005 8:33 pm
by SupraLux
Need to know the ratio... give us the tran/axle code from your plate on the firewall or post the ratio if you know what it is.
Also, are you certain its the diff and not something in the driveline around it?
Steve
Posted: Fri Dec 09, 2005 7:45 pm
by 4wdnuts
hi steve, trans/ axle code is g52 g285. im pretty certain its the diff as i have it on jack stands at the moment and had it running. i put a screwdrive on the diff housing and all the noise seemed to be coming from that area.
Posted: Sun Dec 11, 2005 5:34 am
by SupraLux
Yep, well G285 is a 4-pinion LSD 4.3 ratio, so your best and cheapest bet will be Tims open one he mentioned above otherwise start shopping for a 4.3LSD - which will probably set you back at least $400 if you can find one outside of a wreckers... any wrecker with one will probably want well more than that.
Best bet will be to remove it and check to see whats happened - it might be a bearing which can be replaced, or it could be rust-induced early retirement - in which case it will make a nice (and VERY effective) paperweight
regards
Steve
Posted: Sun Dec 11, 2005 7:59 am
by 4wdnuts
thanks for that steve, i will get in contact with tim. do you have his number i can contact him on?
Posted: Mon Dec 12, 2005 7:50 pm
by 4wdnuts
thanks for that guys. tim can you give me a ring about your diff. am very interested. call or txt me on 027 222 8793 or 03 383 5517.
scott
Posted: Tue Dec 13, 2005 5:18 am
by hosehustler
will ring your cell today
Posted: Tue Dec 13, 2005 4:34 pm
by JJ
I have an old 4.3 LSD but you would need to tighten it up a bit. Open to offers. Its cluttering my garage. I put in a 4.8. Cell 0274447734.
Posted: Tue Dec 13, 2005 5:30 pm
by 4wdnuts
sounds good, will give you a call tommorrow if i dont hear from hosehustler.
Posted: Wed Dec 14, 2005 7:05 pm
by 4wdnuts
sorry tim ive lost your number. can you give me another call?
