while on a drive ysterday, at lunch the radio was going with the prs. and then it all stopped.
no clock, no radio, no prs, no a/c ,no fan, no cigi ligter too
i checked all fuses while on the track an didnt find any blowen but ill be out there soon with the meter.
does any one hve any ideas please.
jono
vx electic problem
Re: vx electic problem
add in no mirror controls too.
time to consult the manual an look thrugh the wiring diagrams
did you check the fuses visually or with a meter?
out on the track visual. just got back from buyin more fuses, found one blown,
runnin new power feed for radios and feeding it from the power outlet socket.
also running in cab winch control cable
Have you checked the engine compartment fuses, passenged side in front of the shock tower.
my lux did that and found out that it was the 60amp fuse under the bonet had blowen
im embarshed to say it was the cig fuse. i use the manual nd all the dead items lead to it so i metered it an wala dead fuse.
at lest i know have spare fuses for when out on the tracks
cheers jono
cheers jono
