winding back kms of cluster
Windsurfer0206
Post by Windsurfer0206 »
ok i have founf a new 3y-e cluster but it is at about 255,000 and my yn60 surf has only done 165,000 kms. how do i wind the kms back to the right amount? i know it has to do with having a drill but were do i connect the drill to?
cheers chris
j_tomo
Re: winding back kms of cluster
Post by j_tomo »
i "hear some peolpe" do it by pulling the cluster apart and popping the small circlip off the the shaft that holds the numbers together, set it to what you want, put the circlip back on, assemble evrything back up
this is the only way to do it with out mucking up the number possition
Windsurfer0206
sweet cheers for that ill give that a go.
fj40
Post by fj40 »
just pull it out of the truck pull the clear plastic front off use a tiny screw driver and just flick the numbers not that i know how to do that :lol: :lol: :lol: :lol: if u pull ya nedel off when ya put it back on it prob wont read correct :wink:
its not how big the 4x4 is its how angry the diver is
Windsurfer0206
got home last night and the new one was sitting at the door so i pulled it apart and pulled my old one aparts and just took the whole speedo section out of my old cluster and just put it into my new one. easy as that.
cheers guys
chris
