hey i have done a self diagnostic on my surf after getting everything in and the engine check light is staying off then blinks 8 times then off for few seconds then blinks 11 times.
i have looked through my manuals and cant figure out what it is. the closest i can see is my air sensors.
can anyone help
chris
3y-e question
- Windsurfer0206
- muddyhilux
Re: 3y-e question
hey chris,what sort of symptoms are u getting?just looked through my manual and checked the codes but yeh,ive never had those 2 before,ur truck manual or auto etc?
Re: 3y-e question
Windsurfer0206 wrote:hey i have done a self diagnostic on my surf after getting everything in and the engine check light is staying off then blinks 8 times then off for few seconds then blinks 11 times.
can anyone help
chris
first number is first nymer second number is second number
there are no codes above 99
are you sure you get 11 ?? is it a auto ??
Kiwi4x4
- Windsurfer0206
Re: 3y-e question
its a manual and yeah sure it is 8 then 11.
chris
chris
Re: 3y-e question
then you have a sigle digit system
so your code's are 8 and 11 .. not 811
code 8 is
INTAKE AIR TEMPERATURE SENSOR SIGNAL--OPEN OR SHORT IN INTAKE AIR TEMP. SIGNAL
--INTAKE AIR TEMPERATURE CIRCUIT
--INTAKE AIR TEMPERATURE SENSOR
--ECU
and 11
SWITCH SIGNALS
IDL (tps) CONTACTS OFF, NEUTRAL START SWITCH OFF, A/C SWITCH "ON" SIGNAL TO ECU
WITH DIAGNOSTIC CHECK CONNECTOR SHORTED
--A/C SWITCH/CIRCUIT
--A/C AMPLIFIER
--TPS/CIRCUIT
--NEUTRAL START SWITCH/CIRCUIT
--ECU
http://www.off-road.com/toyota/tech/codes/
hope that helps
code 8 is
--ECU
and 11
SWITCH SIGNALS
--A/C AMPLIFIER
--TPS/CIRCUIT
--ECU
hope that helps
Kiwi4x4
