nissan lift
nissan lift
putting a lift in my safari , have bilstein shocks 620mm ctre to cntre and two 30mm spacers going too
Re: nissan lift
What size lift you running?
Re: nissan lift
got a 75mm EFS kit yesterday
- Andrew1706
Re: nissan lift
Time for 35s now Coxsy.
Re: nissan lift
Were the shocks for the rear? I run 75mm Dobinsons with OME shocks which are 716mm extended
- flyingbrick
Re: nissan lift
coxsy wrote:got a 75mm EFS kit yesterday
did you get the heavy duty front springs?
Any idea of the part numbers and cost?
Re: nissan lift
heavy fronts NISHL3E $360 shocks EFS36 5548 397-654 mm big bore
Re: nissan lift
bout time aye, should do the trick
Re: nissan lift
no to 35's not made of money
Re: nissan lift
oh forgot need a rear lower radius rod i got a slight bent one
- flyingbrick
Re: nissan lift
I reckon it'll flex a little more than that
Re: nissan lift
thats just my underside wash stand, have done more than that on track
Re: nissan lift
finished road tested
