surf offset rims
safaripete
surf offset rims
Post by safaripete »
will independent front end surf offset rims fit on landcruiser?
have found some 15X8
Re: surf offset rims
nup
fairly confident they will foul on the tierod ends
safaripete
dam will keep looking
wopass
Post by wopass »
try them if you can, some do and some dont :wink:
as skiddy said, some are set in too far and hit rod ends,depends on front end set up also if it has disk setup they may fit anyway... best to try.
safaripete
wopass wrote:try them if you can, some do and some dont :wink:
true they are only 100 bux so cant loose really
could buy them and cut centres out i guess
BUY THEM
if they dont fit, then you just cut and flip the centres, then they will rock dude
