Wanted - Air hose for Lexus 1UZ FE
MNC
Post by MNC »
Hi Guys,
I'm after the bit circled in red. Need to source one before 22nd so would appreciate any help finding one.
Re: Wanted - Air hose for Lexus 1UZ FE
Is that a pod filter you are running? :oops: good for sucking up water :D
Theres a few potential sources on TM...
http://www.trademe.co.nz/Trade-Me-Motor ... 457712.htm
http://www.trademe.co.nz/Trade-Me-Motor ... 373712.htm
http://www.trademe.co.nz/Trade-Me-Motor ... 538377.htm
vvega may be able to help as well?
I'm on the lookout for the front plastic cover (near the coil pack) and the 2 inner side covers (over the wiring) for mine
vvega
Post by vvega »
i have all those bits
ill sort out pricing tonight :D
Kiwi4x4
Hmmmm Mine appears to have an extra thingy on one side, seems to be relay or something which is connected to the loom with 2 vacuum pipes, 1 connected the other which has been cut which i've blanked off. any idea what its for?
I'm not sure if I need this hose either, Its been blanked off, it appears to go to the air pipe but I ain't running an airflow meter (Running a Link instead of the factory ECU), pulling the blanking pipe off makes the motor rev more at idle....
Want some of the bolts for the outer covers as well as I'm missing some.....4 would be good
MNC
Post by MNC »
vvega wrote:i have all those bits
Cheers dude,
