somthing a little different
tristanp
Post by tristanp »
ive had an idea to build a buggy for a while, so this week ive started a little work on it.
the idea is to take a front wheel drive motor and box, mount it north south and run driveshafts from the front wheel drive diff to a set of 4x4 diffs.
last week i picked up a toyota corolla 4afe engine +auto trans, im no good with computers and stuff so ive removed the fuel ingection and built a manifold for some GSXR1100 motorbike carbs i had using the old intake gasket and a local profile cutter and some exhaust tubing flared out to 41mm (same as the bike carbs)from the muffler shop.
a few months ago i bought a lwb mq patrol without an engine and trans and stripped the body off the chassis- this will be the test rig to see if it will work.
so today ive half mounted the engine/trans into where the driver would have originally sat in the patrol making sure to keep the lowest part of the engine/trans as close to the height of the bottom of the chassis rails as poss.
its going to look a little mad max for a while but it should give me an idea on performance and gearing - biggest problem i can see so far is im pretty sure a normal transfer case low ratio is 2:1 and the corolla engine runs 3:1 diff gears but i figure how much time do you spend int he upper gears in low ratio anyway.
tomorow i will sort out a bit more engine mounting and get the radiator mounted then start to sort out some adaptors from corolla cv shafts to patrol diffs, then start looking at brakes and engine controls and a seat
i will upload some pics soon
De-Ranged
Post by De-Ranged »
:D :D Pictures Please!!
Leaves the question where do you plan to sit ???
LWB is an iteresting option for this... you gona shorten it any??
More, More 8)
Cheers Reece
tristanp
Post by tristanp »
i was thinking of sitting right out the back-or right up the front away from my home made driveshafts...no im going to keep it lwb for now..
like i said, its gonna be a little mad max looking , but its only to test if the idea will work. if it performs well i will take out the engine and diffs and start on a tube frame
tristanp
Post by tristanp »
perfect balance? - gotta love that front engine crossmember
motorbike carbs all mounted up - driveshafts ready for adapting
De-Ranged
Post by De-Ranged »
How about like the american rock crawling buggies and offset the motor and sit next to it ....
Trust me don't set the seat infront of the front axle 8) my old man built a farm hack that was like that and it was very disconserting to drive :lol: especially on drop off's !!
If your worried about your drive shafts build some rings for them (same as the drag boys do incase they blow UJ's, just to stop them flailing if they go....
:D Lookin pretty crazy :twisted: more more...
Cheers Reece
klompy
Post by klompy »
You will have to figure out a way to lock the corolla diff. Like Rover do or just permanently.
tristanp
Post by tristanp »
i already pulled the head out and welded the spiders
round here we call that the lincoln locker
Cloggy_NZ
Texas Chainsaw
Post by Cloggy_NZ »
Absolutely love it!
These kinds of home built buggy's are right up my alley.
The lower gearing won't be a problem, it will probably be an advantage as the Corolla engine will only have about a third of the torque the original engine put out. And most of that torque will be fairly high up the rev range. The automatic is a good choice as it will make up for the lack of low down grunt somewhat. I would definitely do the "Lincoln Locker" thing to the differential in the auto box.
Keep the pics coming :D
SupraLux
Complete Bastard
Post by SupraLux »
I live for this kinda stuff :) I love it... keep up the good work, and the frankenbuggy look is in this year so go fashionable and keep it how it is :)
More more :)
Steve
tristanp
Post by tristanp »
my drive shafts (cv axels) are two different sizes, 22mm & 29mm so ive figured out if i lay them both in the v of an angle iron and space up the smaller shaft 3.5mm - clamp it togeather and weld it up it should be straight enough.. should i use low hydrogen? preheat? or just mig it up ?
tristanp
Post by tristanp »
well another night on it tonight,
used the angle iron as a giude and stuck the shafts togeather, this is the back one, ive used the longest corolla one i could find and added 300mm and welded a flange to the last cv
the front ones were a little harder, since its already beed modified, there was still a carrier and cv shaft attached to the front diff so i had to weld these in place
just like a bought one..
done
mounted the radiator
then the fun bit, i couldnt be bothered putting it up on axel stands so i drove it back and forward -looks straight enough- hopefully tomorow i will get some sort of steering organised and start looking around for a pedal box, then all i have to do is tune the carbs (way too lean at the moment) and hook up the brakes
Cloggy_NZ
Texas Chainsaw
Post by Cloggy_NZ »
Have you decided on a seating position yet?
tristanp
Post by tristanp »
tonight ive run the steering shaft up beside the motor to the back of the gearbox, the seat will end up just infront of the rear axel, so im going to fit a driveshaft loop (incase the join breaks)& im thinking about sorting out a sheet of steel to put under the seat for added protection, not much work on the old girl this weekend as im headed off for the long weekend and the following two weekends are pretty much rooted as well so it will be evening work only
mike
Last minute Mike
Post by mike »
This is so dam cool 8) ..... when your done get a pic with you sitting in it and I'll post it up on the front page for awhile if you want :D
Mike
1973 SWB Land Rover V8 Hybrid
1994 Toyota Surf
SupraLux
Complete Bastard
Post by SupraLux »
How about creating an Isuzu forum before you do that :evil: :lol:
Hey, its looking very cool tho, keep up the crazy-ass work and the photos :)
Steve
dazza85
Post by dazza85 »
Got to agree with Steve
That beast looks awsome,
Keep up the Frankin-buggy building
Daryle
tristanp
Post by tristanp »
i spent a few hours on the beast today, welded in the seat,sorted the steering and connected a makeshift shifter to the trans
then it was on to the carbs, ive read up a bit latley about how you can re-jet the CV carbs by lifting the main needle with washers so here we go
carbs come apart easy enough- ,
just a circlip holding it all togeather
this is the original needle, see the grooves for the circlip
and this is where i moved the clip to
and they now run real sweet, maybe a little lean , but it revs real clean and hard
so i figure i need to take this thing for a spin, who needs brakes and a gas pedal anyway.. so i rig up a h20 bottle as a gas tank and mount it up a pole i welded to the chassis , then i hook up an accelerator , just a bit of wire hooked on the throttle wheel and tied off to the top of the pole i just welded for the fuel, ive also hooked up the ignition and starter circut to the light switch on the wheel so i can kill it easy enough....
and it hauls ass, 1st gear is a bit low(good for a crawl gear) and 2nd and third pull really strong, i figure i will have a little fun with it over the next week or so , then pull it down and start the real build up with a tube frame
tristanp
Post by tristanp »
the light switch is perfect, ignition on is park and start is headlights on, i could have used the washer circut, but the light switch works good
Heath
Post by Heath »
Insert Frankenstein laugh 'ITS ALIVE, ITS ALIVE".
Sometimes ya gotta think out of the square just because you can...Love it.
Heath
dazza85
Post by dazza85 »
Wow :shock: :shock:
Looking great !! :D :D :D :D
Thinking Outside the square works for me to :idea: :idea:
Cloggy_NZ
Texas Chainsaw
Post by Cloggy_NZ »
Damn, kicking myself..... :scratch:
Spend big dollars a couple of years ago on a drag car trying to get the fuel pressure right. Electric pumps, fuel regulators, surge tanks....... :?
And all I really had to do was mount the fuel tank up a pole :!:
Instant infinitely adjustable fuel pressure on a budget. Vary the length of the pole to increase or decrease the pressure.
Now why didn't I think of that :(
Absolutely love it :salut:
SupraLux
Complete Bastard
Post by SupraLux »
What can you say to that... not sure wether to laugh, cry or shake your hand :lol:
Its AWESOME... I love it.
Steve
tristanp
Post by tristanp »
ok, the fuel pole idea was a little rough but the bike carbs dont seem to handle the pressure a pump provides , i figured that in a bike its only gravity that feeds the carbs so gravity i will give it, will have to figure another way round this - a loop fuel system or replacing the float springs in the bowl
maybe today i will pick up a pedal box and get some brakes , or properly sort the fuel problem
Cloggy_NZ
Texas Chainsaw
Post by Cloggy_NZ »
Nah, leave the fuel up the pole. It adds to the whole insane look of the thing.
Kinda reminds me of a patient in a hospital (could that be a mental hospital?) walking around with a drip feed hanging of a pole.
De-Ranged
Post by De-Ranged »
:thumleft: great work :D :D :lol: I can't wait to see some action shots!!
Had a comp grass kart that had fuel problems tryed alsorts, electric pumps, crank case pumps different float valves, springs etc .... and in the end the pole trick was the only thing that worked reliably 8) :lol:
Hey how'd those welds spin on your axles, I was a bit slow in saying watch out for warpage 8) .... all good ???
Cheers Reece
tristanp
Post by tristanp »
well , i can get all fours spinning quite easily, and ive been using reverse as a brake so the shafts have taken a hiding. the shafts arnt perfectly straight and i can see a wobble (down through between my legs) but they apear to work well . ive got a 9lt s/s fire extinguisher thats been converted into a fuel tank , so i might get some brackets welded on and mount it above the head and use gravity- ive really got to sort out the brakes though
SupraLux
Complete Bastard
Post by SupraLux »
You could always have a sensible low-mounted main tank with a pump feeding a header tank over the carbs, with a return line back to the main tank so its always full but theres a gravity pipe in the bottom feeding the carbs all they need.
It would only need to be 500ml or so, so could be very compact... saves making the buggy look like it just escaped from the emergency ward at the local hospital :P
Steve
