Locker for high pinion front diff?
Ive got a 4.3 high pinion front diff off a landcruiser prado it think, just wondering if anyone out there is running a lockright in it if so what kinda, ive got a 1610-lr for 8" toyota but unsure if it will fit a high pinion??
Re: Locker for high pinion front diff?
just put a 4 spider hub out of a hilux in the front and i think you can use the same locker as the rear in them as far as i no, the original front is a high pinion but only has a 2 spider hub so the locker costs more
- hosehustler
hitbiga wrote:Ive got a 4.3 high pinion front diff off a landcruiser prado it think, just wondering if anyone out there is running a lockright in it if so what kinda, ive got a 1610-lr for 8" toyota but unsure if it will fit a high pinion??
The 1610 LR will fit your prado high pinion diff, I fitted one to mine (Prado axle in surf), just checked the order and that part number is the same
I hate signatures
ok cheers.
