i should probably know the answer but i need some one to tell me i think, is it possible to fit a pto winch to a 70 series 4.2 diesel automatic? i can't remember if the pto fits to the g/box or transfer
Pedro
stupid winch question
Re: stupid winch question
Yep,, PTO will fit the transfercase.
The big question is does your transfer case have the drive gear in it or do you have to split the case to fit it. Pull off the PTO cover on passenger side of transfer box to see if you have the gear.
Good luck
Good luck
mudmike wrote:The big question is does your transfer case have the drive gear in it or do you have to split the case to fit it. Pull off the PTO cover on passenger side of transfer box to see if you have the gear.
Good luck
well that may be a little difficult
Pedro
