Having issues sorting steering on a vehicle. Anyone got one of these? Mainly need the RH end off one plus some of the tube - no biggy if tube is bent. Thread of tierod end is Approx 17mm (LH thread)
Off LN46 or 56 Model. 1981-1983.
Closer to auckland the betterer
Thanks
81-83 hilux Steering Arm wanted (one that goes between hubs)
Re: 81-83 hilux Steering Arm wanted (one that goes between hubs)
I have a slightly bent one you can have. If you only want the ends and a bit of the tube I can always cut it down and send it down. Not sure I will down that way next, or could try the ORE courier.
