as soon as i hit 3k on rev counter in 3-5 gear the red light from the turbo comes on. i have recently put the biggert exhaust on it, also replaced turbo due to blown seals and the airflow sensor on the side of the air filter box, and the external waste gate. so whats happening can anyone help.???????????????
jase
another ln130 issue
another ln130 issue
- rangimotors
Re: another ln130 issue
Could be wrong but i think that red light means its over boosting eg more than factory boost level. This will be from your bigger exhaust and other mods, if you are monitoring you boost levels with a gauge an egt's then i don't think its anything to worry about.
can you reset thefactory boost level to get rid of it
