Any info also appreciated.
WTD Winch - Electric or PTO LJ78
- Landcruiser70
- Bush Crasher
Want a winch for the Prado looking for something relatively cheap but reliable. Been looking into the PTOs but they seem a bit hard to come across? And from what I understand there could be a bit of farking around to get one on.
1993 Landcruiser Prado LJ78: 4" lift, Tough Dog sus, 35" BFG muds, ARB air locker, LSD
Re: WTD Winch - Electric or PTO LJ78
for the PTO your transfercase may or may not have the pto bits.....something you will need to check....
you will need the pto drive gear and spacer, Don Kyatt in manukau can get for you, that is if you can't find a second hand one.
I put on a 60series pto and had shafts shortened. there is a bit of messing around and some custom brackets to be made, also need to cut hole in floor. this model did not have pto as option so no cover for it. Any more questions give me a pm I can send pics of what i've done if it helps.
Good luck
Good luck
