Pto winch oil??
dawwen
Pto winch oil??
Post by dawwen »
I once again ask for advise.
I'm aware certain types of oil can and cant be used in a toyota pto winch as it has brass gears.
The question is what can and cant be used.
I've been told by bnt redline lightweight shockproof can be used,
Is this correct.
I'm not keen on stuffing my winch after the time i've spent replacing seals etc.
Thanks for the help
Darren
Re: Pto winch oil??
TOTAL Carter EP680 or ELF Reduct-Elf SP860.
wopass
Re: Pto winch oil??
Post by wopass »
SHC 634 is what im running in mine now for the high load and high speed oil temperature reduction capabilitys.
but the total gear oil is good to i hear
muddy
Re: Pto winch oil??
Post by muddy »
I've just been using standard Hypoid 90 Gear Oil. Is that not good?
mudtroll
Re: Pto winch oil??
Post by mudtroll »
Same oil for Nissan PTO?
Re: Pto winch oil??
Toyota specs
API GL4
SAE 85W-90
300ml
:mrgreen: :mrgreen:
