How to cut the guards on my XJ Cherokee
Posted: Thu Nov 19, 2009 4:09 pm
by sneek010
Hi, I have just tried to fit 32x11.5 to my xj which has a 2" Lift kit, but when a turned the wheels they crash into the guards, can you explain to a total novice how I go about cutting the guards? Step by Step please.
Re: How to cut the guards on my XJ Cherokee
Posted: Thu Nov 19, 2009 4:31 pm
by yeti
by Lynx
s
Posted: Thu Nov 19, 2009 5:34 pm
by xj
if you send bb240c (???) a PM he maight be able to help.
Posted: Thu Nov 19, 2009 5:45 pm
by downunderxj
Try this
http://www.naxja.org/forum/showthread.php?t=101158. However it is a bit old and the photo links are broken. HOwever I have a pdf that I could email you if you send me your email address by PM. I have done my front guards, but not the rear ones yet.
Ian
Posted: Thu Nov 19, 2009 6:50 pm
by sneek010
This may be beyond my capabilities... is there anyone in Auckland I could pay to do this?
Posted: Fri Nov 20, 2009 8:46 am
by DAJEEP
its ezy as just get a grinder with a 1mm cut of wheel and start cuting were the tyers rub
Posted: Fri Nov 20, 2009 11:38 am
by flyingbrick
way safer, less stressful and easier using a cheap jig saw with a steel cutting blade.
Posted: Fri Nov 20, 2009 11:48 am
by xj
wherenever i try to cut anything with a jigsaw its goes offline horribly... and thats straight... heaven knows what would occur if i tried cutting on an angle!
Posted: Fri Nov 20, 2009 12:03 pm
by flyingbrick
ahahahaha. its surprisingly easy. Just mark out the cut with a clear sharp line and take it real slow.
If you need a hand in hams and will supply the ginger beer i can pop over
Posted: Fri Nov 20, 2009 12:14 pm
by xj
flyingbrick wrote:ahahahaha. its surprisingly easy. Just mark out the cut with a clear sharp line and take it real slow.
Sadly I am afflicted by the left-handedness... same thing happens when slicing bread with a serrated knife. Come to think of it, the same thing has been known to happen while driving!
(and youre welcome around any time, providing you supply the ginger beer!)
