How to cut the guards on my XJ Cherokee
Hi, I have just tried to fit 32x11.5 to my xj which has a 2" Lift kit, but when a turned the wheels they crash into the guards, can you explain to a total novice how I go about cutting the guards? Step by Step please.
Re: How to cut the guards on my XJ Cherokee
hi mate , have a search through here http://www.ausjeepoffroad.com/forum/for ... .php?f=124
v8 tj...luvs the gas......
if you send bb240c (???) a PM he maight be able to help.
/| , [____],
l----L -OlllllllO-
()_) ()_)-----)_)
KEEP'N JEEP'N!
l----L -OlllllllO-
()_) ()_)-----)_)
KEEP'N JEEP'N!
- downunderxj
Try this http://www.naxja.org/forum/showthread.php?t=101158. However it is a bit old and the photo links are broken. HOwever I have a pdf that I could email you if you send me your email address by PM. I have done my front guards, but not the rear ones yet.
Ian
Ian
'95 Jeep Cherokee (XJ)
1936 Ford Flathead V8 Colonial Cab (restoration project)
This may be beyond my capabilities... is there anyone in Auckland I could pay to do this?
its ezy as just get a grinder with a 1mm cut of wheel and start cuting were the tyers rub
- flyingbrick
way safer, less stressful and easier using a cheap jig saw with a steel cutting blade.
wherenever i try to cut anything with a jigsaw its goes offline horribly... and thats straight... heaven knows what would occur if i tried cutting on an angle!
/| , [____],
l----L -OlllllllO-
()_) ()_)-----)_)
KEEP'N JEEP'N!
l----L -OlllllllO-
()_) ()_)-----)_)
KEEP'N JEEP'N!
- flyingbrick
ahahahaha. its surprisingly easy. Just mark out the cut with a clear sharp line and take it real slow.
If you need a hand in hams and will supply the ginger beer i can pop over
flyingbrick wrote:ahahahaha. its surprisingly easy. Just mark out the cut with a clear sharp line and take it real slow.
Sadly I am afflicted by the left-handedness... same thing happens when slicing bread with a serrated knife. Come to think of it, the same thing has been known to happen while driving!
(and youre welcome around any time, providing you supply the ginger beer!)
/| , [____],
l----L -OlllllllO-
()_) ()_)-----)_)
KEEP'N JEEP'N!
l----L -OlllllllO-
()_) ()_)-----)_)
KEEP'N JEEP'N!
