They have always annoyed me and now that all my lights are out, I decided to see how easy it was to remove the yellow part as I'd heard it wasn't too hard.
So these are the lights I'm talking about..................
once you have your headlight out, or you could actually do it in place if you wanted.......
remove the 2 phillips screws......
you will then have an assembly for the bulb that has a yellow lens globe around it, that cannot be removed........
place both yellow globes inside a rag............
fold the rag up so both globes are trapped inside and then carefully smash them with a small hammer
open up the rag and you may have to use some long nosed pliers to extract the remaining bits of glass from the assembly........
then you will be left with an assembly with no yellow globe anymore.........
All thats left to do is put the assmebly back into the light housing using the 2 phillips screws and then replace the bulb or go buy a new one in the sweet blue colour and you no longer have yellow fog lamps.
