Landcruiser 80 series coil spacers wanted
hosehustler
Post by hosehustler »
I'm after some rear coil spacers if anyone has a couple laying around
cheers, Tim
I hate signatures
DieselBoy
Re: Landcruiser 80 series coil spacers wanted
Post by DieselBoy »
I have some 100mm ( 4" ) steel spacers. Would only sell as a complete set though.....
UBZ
Post by UBZ »
are the 80 series the same size as 130 Surf rears? I have 2 x 1 1/2" Spacers at home some where.
hosehustler
UBZ wrote:are the 80 series the same size as 130 Surf rears? I have 2 x 1 1/2" Spacers at home some where.
cheers for the replies, 80 series are slightly larger in diameter than the 130's hoping to find about a 30mm spacer so yours may do the job :mrgreen:
could you measure their diameter :wink:
I have put the std 80series springs back in my surf as they flex a lot better than the aftermarket 80 series Dobbinsons I had in the rear of the surf but just need about 30mm more to stop tyre rub, as I have used a real wide offset rim, if I can't find anything i'll just put the dobbys back in
I hate signatures
Engineer
Post by Engineer »
ive tried 2 different brands of 80 series springs and neither fitted nicely in the rear of my surf.. have u modified the spring seat on the axle?
Thanks
Ryan.
LN130 Surf: Coiled SAS, 35" BFG M/T's, Lifted, Rear Lockright, Snorkel, CB, On-board air
Soon to be 3.8 commy powered, front ARB Air Locker, custom bar work, winch...
MNC
Post by MNC »
hosehustler wrote:..cheers for the replies, 80 series are slightly larger in diameter than the 130's hoping to find about a 30mm spacer so yours may do the job :mrgreen: ...
I'm looking for 2 x 30mm spacers for the front of my 80 (to level it out). If you get a set for a good price let me know and I'll pay for the front 2.
UBZ
Post by UBZ »
Dug out the spacers , even found a pic of them new. 8) :roll:
Downey 4Runner Spacers from the US
30mm Lift
50mm Total Depth , 20mm Deep Recess on bottom for spring seating
Slight Internal taper to match 130 Surf upper spring mount.
Recess diameter to inner wall 133mm
Recess diameter to outer wall 167mm
Recess width 17mm
Inner wall thickness 6mm
Outer wall thickness 7mm
