clutch for 70 series landcrusier
want to replace it and who knows 4 terrain and or terrain tamer?
Was told that t tamer is the way to go but forums in Oz talk positively abt 4 terrain? Who knows what to do and why?
appreciate your help
andy
Re: clutch for 70 series
Depends what you are using the truck for. I've got a 70 and use it hard offroad, water etc etc and its running a standard clutch. Bout 300ish for a clutch kit and haven't had any trouble at all (touch wood)
Unless you have re-powered, a standard clutch should be fine. If it ain't broke, don't fix it... If it's slipping - it may just need a good clean out or new pressure plate. Mud does that...
Where are you?
I have a couple of old clutches lying around - off a 60 series Cruiser with 2F motor. May fit and no cost if you want to try one...
Where are you?
tks matey
planning a little big bigger, continents if I get the $$ together
I am in Tauranga. Have aftermarket Safari Turbo in there plus will carry some weight on the back (cab)
that's why, any feedback abt 4terrain or t.tamer is apprecaited here
tks guys
Andy
tks guys
Andy
give tony a ring at clutch systems chch.i had clutch issues,he helped me out,& also loads cheaper than aussie big name clutches.
tks mate will do
andy
andy
