ln130 independant front diffs
vvilly
Post by vvilly »
long story to cut short what is the plug on the back of the long shaft for.
just put a 4.8 open in the front of mrs truck and the old 4.5 had two vacume hoses and two plugs one on front one on back
the new one only has two vacume hoses and one plug on the front
can anyone help
UBZ
Re: ln130 independant front diffs
Post by UBZ »
rear plug is a over heat temp switch. is normally open so leave disconnected and your all sweet . Front plug is the 4wd indicator switch
vvilly
Post by vvilly »
haha thanks we were just about to take the diff back out and put in another one what a mish
UBZ
Post by UBZ »
just make sure the plug cant short out with water etc or 4wd computer will thinks its overheating and disconnect 4wd.
I cut the wires out further up the loom so it could never happen.
