Play in left front wheel still (bearings replaced and tight)
Posted: Fri Feb 12, 2010 8:52 pm
Hi all
quick thanks to UBZ and BEN for the idle responses i had, all fixed.
Right i replaced my front wheel bearings and have driven around and now tightened them up that last little bit.
My front left wheel still has some play in it. It moves up and down slightly and as it does oil / grease is escaping from the ball joint piece (sorry don't know propper term) on the inside of the wheel. The seal is hanging out and will need replacing that's obvious enough, my question is what is causing the play?
The vehicle is a sj413 87 leafs all around.
Pierre.
Pierre.
