85 hilux auto pedal wanted
flyingbrick
Post by flyingbrick »
Did these trucks come out as an auto with larger brake pedal?
Anyone got one sitting around ?
-Nathan
rokhound
Re: 85 hilux auto pedal wanted
Post by rokhound »
Just make one. All I did for mine was make a decent sized plate out of 3mm and weld it on to the existing foot pedal, but offset it over to the left. Make sure you can get a non slip cover of some sort for it or it won't pass wof (if you are going the legal way)
nzhunter
Post by nzhunter »
rokhound wrote:Just make one. All I did for mine was make a decent sized plate out of 3mm and weld it on to the existing foot pedal, but offset it over to the left. Make sure you can get a non slip cover of some sort for it or it won't pass wof (if you are going the legal way)
Yeh thats a good idea make sure you pull the pedal box out to do it though lol catching the cab on fire is always fun
I've seen that skateboard decking stick on sand paper stuff being used in drift cars etc on the pedals - may be good for 4wding? I duno what it goes like with mud on it
haydgq
Post by haydgq »
flyingbrick wrote:Did these trucks come out as an auto with larger brake pedal?
-Nathan
I used a 130 surf one for mine but had to change the side that the little tab was located that activates the brake light.
