WANTED : Suzuki SJ80 (Coily) Fuel Tank
UBZ
Post by UBZ »
Looking for a SJ80 (Coily 96-98??) fuel tank .
Needed for a 13b EPI conversion as will fit a Vitara swimmer pump and bolt up to the 413 mounts
Surly some one has one lying around in their shed. any thing considered.
Cheers C.
Rotazuk
Re: WANTED : Suzuki SJ80 (Coily) Fuel Tank
Post by Rotazuk »
No tank , but you can cut the pump out of a vitara one and weld it into the top of the samy fuel tank . Could be worth a look if you can't get a coily one .
Will have to mount one in an LJ80 tank when/if I get onto that project :)
Chris
UBZ
Post by UBZ »
yeah that would still be better than a external HP Pump IMO. less chance of leaning it out on angles
the beauty of the coily tank is that its got a in built in swirl pot and baffles.
UBZ
Post by UBZ »
bump
Someone must have one lying around the place
its_that_guy2
Post by its_that_guy2 »
hey bud try my old man at wellington van and ute dismantlers .. 0800 4 826883
ask for Ed tell him shane told you to call and your from here ... im sure he has a couple as i've seen two maybe three shells about 60% there sitting out the back , but i may be wrong or they may be sold . worth a try tho innit :D
UBZ
Post by UBZ »
Cheers Shane , :D :D :D will give him a call on Monday.
UBZ
Post by UBZ »
nope no Coily tanks only vitara and Escudo stuff. :( :(
Bump , anyone else know where i might be able to find one???
muddyhilux
Post by muddyhilux »
could be pricey but have you tried that 4wd wreckers in onehunga,cant remember there name,they usually have heaps of stock in there of all sorts of things ae,theyre down that side street leading to cemetery
QUADRACER
Post by QUADRACER »
Craig at mudbits or Te Pukre parts world,
only reson i used coily tank was because i had one,
you could mod your standard one by makiing surge box
and fitting vitara top ring, ofr complete vitara inner set up
a radiator shop would do this for you.
Cleary
Post by Cleary »
I just run a Honda external pump on mine (alloy fuel tank). Runs at all angles (had to switch it off when upside down after last rollover at Mercer trial). Cheap and easy to replace...
Otherwise try Mudbits.
lilpigzuk
Tiger Balm
Post by lilpigzuk »
Cleary wrote:Otherwise try Mudbits.
:lol: :lol: :lol: Fawk, be cheaper to buy a whole SJ80. And if you try mudbits, also try "seabits" and "cracka8" on TM, seems to be his bidding name to not show his selling username :roll:
