Hi there 4x4ers.
Looking to purchase a set of side gears from a SJ413 rear differential. (SJ410 may be the same)
Maybe someone has a diff head that’s blown up or in bits.
This is the back diff with the larger 26-spline count axle.
Was also available in the steel housing type front Vitara diff. (which is not so common)
Cheers MIKE.
WANTED Suzuki SJ diff or side grars.
- mroffroader
Re: WANTED Suzuki SJ diff or side grars.
Got some side gears, what are they worth to you? cheers
