KZ90 PRADO ,reseting speedo
Just renewed the timeing belt, how do I reset the odometer warning light?
Re: KZ90 PRADO ,reseting speedo
I'm assuming it doesn't have the little rubber gromet on the speedo so you can get to the reset button?
Looks like its electric where as the KZ70 are cable
The other option is there may be a screw on the back of the instrument cluster itself. Usally have 2 positions, where you simply unscrew from one hole and place screw in the other.
Not too familiar with the Prado models, but this may help?
http://toyotaownersclub.com/forums/inde ... opic=51083
With the 90 you need to pull out the instrument cluster and there is a screw on the back, screw it in and out again and the t-belt light dissappears, with the earlier models the screw is on the front
Thanks, DaveM's info did the trick
