Hi All,
I need seven wheel nuts for the Safari factory alloys.
They are the stepped shanked ones with a M12x1.25 thread and a 19 mm shank.
PM me if you can help me out.
thanks
Jase.
Nissan Safari alloy wheel nuts wanted.
Re: Nissan Safari alloy wheel nuts wanted.
hey mate yep i think i have what your after i will look in the garage tonight to make sure i didnt biff them out
JONO250 wrote:hey mate yep i think i have what your after i will look in the garage tonight to make sure i didnt biff them out
Cheers Jono. I appreciate it.
hi had a look i have 20 of these, measured roughly 19mm shank with a ruler (no verniers at home). do you want some pics to make sure thier what your after?
JONO250 wrote:hi had a look i have 20 of these, measured roughly 19mm shank with a ruler (no verniers at home). do you want some pics to make sure thier what your after?
No pics needed. They will be the ones. How much do you want for them? Where are you in NZ? I am going to welly next weekend so may be ablre to pick up if you are in between Tauranga and Welly.
Jase.
hey im up in auckland, so a fair bit out of your way
. hows $20 sound for the lot? i found a couple more kicking around so should be able to make up a full set of 24
JONO250 wrote:hey im up in auckland, so a fair bit out of your way. hows $20 sound for the lot? i found a couple more kicking around so should be able to make up a full set of 24
Sounds good. I am up to Auck on 10 April so could pick up. Where in Auck are you?
Hey I am in henderson, waitakere city, about 15 mins off northwestern motorway
JONO250 wrote:Hey I am in henderson, waitakere city, about 15 mins off northwestern motorway
That works for me. I am headed out to waitakere. PM me your address and a phone number and I will pick them up on the 10th.
Jase.
