Ignition timing on 4y ??
pruggerdore
Been so long since I had the misfortune to play with points Iv almost forgotten how. Need to know base ignition timing setting and dwell setting for a 4y in hilux thanks Clive
- Landy Rover
Re: Ignition timing on 4y ??
8 degrees timing at idle vac advance disconected and 52 degrees dwell. Check your vacum advancer works as well as mechanical advance.
S3 Rover truck cab, injected 186, Sals rear,Toyota P/steer, Safari disc brakes front, R/Rover D/brakes rear, 9500 winch,twin optima batts, roll bar, Disco seats, 33" JTs, scene lamps, onboard air, Front ARB locker.
pruggerdore
thanks 8* was my guess, A working vacuum advance diaphragm took a bit of finding. feel like I'm traveling back in time
